BCS
Occasional Contributor I
ARUBA 225 DHCP ISSUE
Hi All
I have a found a quirk with my Aruba Instant Wireless network.
I have 18 IAP 105's and 2 recently added 2 x 225's. One of the 225's has assumed master of the Virtual Controller but I found a quirk with random ipad/iphones trying to connect on the 225.
I receive an alert saying "
2014/3/21 12:28:47
90:b2:1f:c3:04:7c
DHCP request timed out
AP20 C BLOCK C2.
It then just gives it an IP address starting with 169.254._._
If i then walk over to another AP which is an IAP 105 and turn my wifi on and off my device it then instantly connects.
Does anyone have a similar thing happen or any ideas as to what im missing??
Re: ARUBA 225 DHCP ISSUE
What is providing DHCP on that network?
What version of instant are you running?
Super Contributor I
Need more infromation on your setup to assist you, what is the setup and what is version. Is other client having the same issue?
Normal Guy
AJ
I ran into the same issue with IAP 225 running 6.3.1.2-4.0.0.3 specialy with the 2.4GHZ clients. the clients werent getting the ip address and in the VC it was showing DHCP request timeout.
1st i reduce the power but it didnt work well  and still the clients werent getting the IP address after that disabled the client match, on restarting the IAP i was able to get the ip address.
So far its working fine have to check the behaviour for some time.
BCS
I am using windows Server 2008 R2 to give out DHCP. I have 2 of these running on my network.
The version of firmware is 6.3.1.2-4.0.0.4_42384.
BCS
I use radius to authenticate against windows AD.
I have 20 x IAP 105's and 2 x 225's. I have noted that the wireless network will not run cohesively unless one of the 225's is the master.
I use a virtual controller which is why we bought the IAP series in the first place.
Can you think of anything else which would help.
BCS
When you say that you disabled the client match. What is that and where can I find it on the web interface of the VC?
Can you share the output of ?show tech-support? from your virtual controller?
BCS
I can get onto my virtual controller but where is the location of find tech support?
I find a section called support but it is blank.
If you are in the UI, please click the ?More > Support? link, and then select ?AP Tech Support Dump? from the first drop-list, select the AP you are having trouble with in the second drop-list, and then click on Run to see the output.
