last person joined: 5 hours ago
Airgroup basic question?
  • 1.  Airgroup basic question?
    Posted Mar 20, 2014 08:38 PM
    Hi All,
    Does airgroup only work on the IAP-105's when the VC/IAP is handling the VLANS itself?
    If a VLAN is set as static and network assigned, then will Airgroup not work?
    Rob.
  • 2.  RE: Airgroup basic question?
    Posted Mar 20, 2014 09:38 PM
    OK so I have Arigroup enabled and also guest bonjour multicast.
     I can see apple TV's and epson printer and Denon amplifier on the Airgroup servers, but on iphone/ipad I only see the Denon Amplifier visable on Airplay devices!
    Any ideas?
  • 3.  RE: Airgroup basic question?
    Posted Mar 21, 2014 03:38 PM
    Now I can see some Apple TV's. But not all, the Cache looks OK on AirGroup servers page?!
  • 4.  RE: Airgroup basic question?
    Posted Mar 22, 2014 10:07 AM
    Are the clients in the same subnet as the airgroup devices or a different subnet?
    Are the subnets separated by a NAT boundary?
  • 5.  RE: Airgroup basic question?
    Posted Mar 24, 2014 09:47 AM
    Clients were a mix, one SSID is on the same VLAN as the Apple TV's the other 3 on seperate VLANs, but they are not NAT as there is a L2 switch handling the routing and VLANS.
    In the end with the help of Aruba I managed to get all the 8 apple TV's showing on the airplay of the device, this was achiveved with a firmware downgrade. I am still yet to test the airplay fully and see if its usable and quick.
