AppRF and AOS 6.4.4 not working
  • 1.  AppRF and AOS 6.4.4 not working
    Posted Apr 30, 2016 02:19 PM
    Anyone else having an issue with AppRF and AOS 6.4.4?? I can't get AppRF to enable no matter how many time I reboot and try to enable and it always comes back as disabled.
    ArubaOS (MODEL: 205), Version 6.4.4.3-4.2.2.0
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2015, Aruba Networks, an HP company.
    Compiled on 2015-12-19 at 00:04:30 PST (build 53034) by p4build
    FIPS Mode :disabled
    Thx,
    D
  • 2.  RE: AppRF and AOS 6.4.4 not working
    Posted Apr 30, 2016 02:21 PM
    You should try upgrading to 4.2.3. Let me know if you have problems getting that.
  • 3.  RE: AppRF and AOS 6.4.4 not working
    Posted Apr 30, 2016 09:40 PM
    Yep, that did it!
    Thx,
    D
