Aruba IAP-204-RW Speed Issue
  • 1.  Aruba IAP-204-RW Speed Issue
    Posted Jun 14, 2016 06:33 PM
    Why does one of my IAP-204-RW's only run at 100mbs where another AP runs at 1000mbs using the same switch port?
    Ethernet led flashing orange denoting 10/100 Mbps whereas other AP Ethernet led flashing green 1000mbps
  • 2.  RE: Aruba IAP-204-RW Speed Issue
    Posted Jun 14, 2016 06:37 PM
    Try swapping the cable between the AP and the switch..
  • 3.  RE: Aruba IAP-204-RW Speed Issue
    Posted Jun 14, 2016 07:12 PM
    Also, is the switch POE or are you using injectors, and if you are using an injector, what is the injector model? That should be swapped out/removed as well if you are testing line integrity between switchport and AP.
  • 4.  RE: Aruba IAP-204-RW Speed Issue
    Posted Jun 15, 2016 02:04 AM
    The switch is PoE (HP V1910-24G-PoE - JE007A).
    Plugging another AP (same model) into same switch port runs at 1000mbps. Hoping its a patch lead between the AP and the switch.
  • 5.  RE: Aruba IAP-204-RW Speed Issue
    Posted Jun 14, 2016 07:21 PM
    Hi
    please check
    • the cable between the switch and the IAP
    • the speed of the port (is it  auto or manually configured to 100 mbps or 1 gbps).
    Regards
  • 6.  RE: Aruba IAP-204-RW Speed Issue
    Posted Jun 15, 2016 01:59 AM
    The cable will be changed. I will advise results when done.
    The switch port is set to Auto.
  • 7.  RE: Aruba IAP-204-RW Speed Issue
    Posted Jun 19, 2016 01:32 PM
    This issue has been resolved.
    The cat5 cable wiring was not correct.
