Aruba Instant Access Point Speed vs Tplink Speed
  • 1.  Aruba Instant Access Point Speed vs Tplink Speed
    Posted Oct 08, 2017 05:44 PM
    I have a wierd problem with my instant APs, i have internet link with 100 mbps speed, when i connect a tplink access point it gives me about 70mbps on speed test but on aruba speed dosen't go more than 40mbps.
    I tried many firmware versions for IAP 103 and i tried to replace them with IAP 207 with no progress, i tried also to change the multicast/broadcast setting and no hope!!!
    Some times i noticed that the noise is high on the access points what should that mean?
    Please any one have somthing like this? what should i do more or i should open a case?
  • 2.  RE: Aruba Instant Access Point Speed vs Tplink Speed
    Posted Oct 10, 2017 08:44 AM
    Any update please???
