Can you use two IAP205s to form a wireless bridge? They will be c. 20m apart
  • 1.  Can you use two IAP205s to form a wireless bridge? They will be c. 20m apart
    Posted Feb 16, 2017 09:01 AM
    I am looking to connect a remote building to an existing network.  Can you use two IAP205s to form a wireless bridge?  They will be c. 20m apart.  Or do I need to use IAP204s with directional antenna.
  • 2.  RE: Can you use two IAP205s to form a wireless bridge? They will be c. 20m apart
    Posted Feb 16, 2017 09:18 AM
    Can you use two IAP205s to form a wireless bridge?  Yes.
    They will be c. 20m apart.  Or do I need to use IAP204s with directional antenna? IAP204s with directional antenna would likely be better in this instance however there are many variables which would dictate what AP/antenna you should use for wireless links.
  • 3.  RE: Can you use two IAP205s to form a wireless bridge? They will be c. 20m apart
    Posted Feb 16, 2017 10:18 AM
    @Aodh wrote:
    It is possible to do this with an IAP205.  If you have an IAP205 already, you should try this to see if it meets your requirements.  If you do not have IAP-205s, you should get an 2 IAP204 with external antennas.
    http://community.arubanetworks.com/t5/Controller-less-WLANs/Aruba-Instant-4-1-Mesh-Configuration/ta-p/214943
  • 4.  RE: Can you use two IAP205s to form a wireless bridge? They will be c. 20m apart
    Posted Feb 16, 2017 10:21 AM
    Thank you both.
