Casting not working IAP-205 & 215
  • 1.  Casting not working IAP-205 & 215
    Posted Jun 11, 2017 05:10 PM
    This is my home network. Flat network. Cisco 3560G PoE for layer 2 connected to an Asus rotuer for layer 3. I've got a Vizio smart TV and Nvidia Shield wired into the switch. iPhones and Android phones wireless to the Aruba IAP-205 and IAP-215 which are paired together.
    I'm new to Aruba, but have Cisco wireless experience. I've tried finding all the different multicast options as well as scoured the forums for answers, but nothing I try works.
    Connected to the Asus router's wifi I can cast youtube/netflix videos to both devices. When I connect to the Aruba wifi the casting options is gone. Any ideas? Let me know if more information is needed.
  • 2.  RE: Casting not working IAP-205 & 215
    Posted Jun 11, 2017 05:53 PM
  • 3.  RE: Casting not working IAP-205 & 215
    Posted Jun 11, 2017 06:20 PM
    I currently have all of those enabled to allow everything.
  • 4.  RE: Casting not working IAP-205 & 215
    Posted Jun 11, 2017 06:34 PM
    What version of Instant code and what OS is the device you are using to cast,?
  • 5.  RE: Casting not working IAP-205 & 215
    Posted Jun 11, 2017 06:36 PM
    6.5.2.0 on the APs
    5.2 on the Nvidia Shield
    iOS 10.3.2 on iPhone 6S
  • 6.  RE: Casting not working IAP-205 & 215
    Posted Jun 11, 2017 06:41 PM
    I would try disabling Broadcast Filtering in the advanced configuration of the SSID and uncheck bonjour and DLNA in Airgroup.  Try those two steps and see if it is working.
    Lastly, I would try an android device to do the casting to see if there is a difference.
  • 7.  RE: Casting not working IAP-205 & 215
    Posted Jun 11, 2017 06:45 PM
    Disabling DLNA and bonjour did the trick. No idea why, but thanks!
