Clients randomly disconnect and not be able to get an dhcp address on instant 105s.
  • 1.  Clients randomly disconnect and not be able to get an dhcp address on instant 105s.
    Posted Sep 27, 2013 08:52 PM
    This customer has an instant deployment of 20 IAPs
    The customer is experiencing an issue where wireless clients will randomly disconnect and not be able to get an dhcp address. The client has to reconnect and may or may not get right back on. This only happens when there are a handful of clients on the AP, sometimes as few as 6.
    The alert in the Virtual controller is that the dhcp has time out on the client.
    I originally was leaning toward this issue being with the clients network and DHCP Servers.
    So I configured a demo Aruba switch and put DHCP on it. I used different SSIDs, brand new VLANs for the wireless networks. Pretty much a completely new network, all Aruba equipment.
    I put 6 Aps from one of the customers closets on the controller with a new and simple config on the instants. The client is still experiencing the same issue.
    Aruba Support really has not been much help they keep on pulling up wireshark hoping that we will see a DHCP request without an acknowledgement from the server. Every DHCP request had an acknowledgement in the packet captures. Aruba Support is going to do more research...
    The customer has been experience this issues since day 1 of the installation, which the client did on his own. The customer notes that the demo he had done with controller based Aps did not this issue and ran for quite some time.
    To put salt in an open wound, the customer has begun putting his old cisco aps back up because he does not experience the issue on his old cisco aps either.
    I just downgraded the instant firmware from 3.4 to 3.3 to see if it would help just as a shot in the dark.
    Configuration wise everything looks good to me. I have attached the configs for the switch and aps that I put together.
    Attachment(s)
    txt
    Aruba-Switch.txt   7 KB 1 version
    txt
    instant.cfg.txt   3 KB 1 version
  • 2.  RE: Clients randomly disconnect and not be able to get an dhcp address on instant 105s.
    Posted Sep 27, 2013 08:58 PM
    Which VLAN is the problem seen on?  Or is it all VLANs and all 3 SSIDs ?
    JF
  • 3.  RE: Clients randomly disconnect and not be able to get an dhcp address on instant 105s.
    Posted Sep 27, 2013 09:29 PM
    It does it on all 3. Like i said this is a demo config so it is pretty simple.
    I was amazed that the same issue was happening with such a basic configuration.
    The same issue happened when the customers production enviroment which used diffrent switches and a diffrent DHCP source.
    There is a bunch of diffrent types of clients Chromebooks, andriod Tablets, iPads and windows laptops. All of them have experienced the issue.
  • 4.  RE: Clients randomly disconnect and not be able to get an dhcp address on instant 105s.
    Posted Sep 27, 2013 10:22 PM
    Whats the ticket # ?
  • 5.  RE: Clients randomly disconnect and not be able to get an dhcp address on instant 105s.
    Posted Sep 27, 2013 10:52 PM
    1457874
  • 6.  RE: Clients randomly disconnect and not be able to get an dhcp address on instant 105s.
    Posted Sep 30, 2013 02:59 AM
    I've seen this same problem with HP gear and Mac laptops. HP support couldn't figure out the problem and the customer finally switched to Aruba and no problems since.
    I never found out for sure what the problem was. I did find a rogue device acting as a dhcp server on the network but to my knowledge the problem continued after it was removed, it just changed shape. Before the clients would sometimes get an address from a wrong subnet but when the rogue device was removed clients just dropped off and couldn't get any address at all. I thought it was unrelated because the connection problem seemed to continue after the rogue device was removed.
    Could be a coincidence but might be worth taking a look.
  • 7.  RE: Clients randomly disconnect and not be able to get an dhcp address on instant 105s.
    Posted Oct 02, 2013 12:52 PM
    Since downgrading the instant firmware from 3.4.0.1_39461 to 3.3.0.3_39227.
    I have not seen an DHCP timeout alert... yet.
    **fingers crossed**
  • 8.  RE: Clients randomly disconnect and not be able to get an dhcp address on instant 105s.
    Posted Jan 29, 2014 12:55 PM
    We've been experiencing the same issue here at school with our Samsung Chromebooks dropping out and not wanting to reconnect to AD. An average day will see 2-5 CB's with "bad address" in the server logs, but some days we've had as many as 15 or more "dropping out". Has there been any confirmation regarding downgrading the controller firmware, or has there been another fix found?
