Cluster IAP 225 and 325
  • 1.  Cluster IAP 225 and 325
    Posted Feb 21, 2018 12:37 PM
    I have a small branch office with a single IAP 225. I have a spare 325 I'd like to add there. Are there any issues with clustering a 225 and 325 together that I should be aware of?
    Thanks!
  • 2.  RE: Cluster IAP 225 and 325
    Posted Feb 21, 2018 12:50 PM
    No.  Just download the datasheet for the 325 and you are running at least that minimum version for your cluster.  You will also need access to the internet so that the 325 can download its updated firmware, if you are adding it to the 225's existing cluster.
  • 3.  RE: Cluster IAP 225 and 325
    Posted Feb 21, 2018 01:27 PM
    Thank you Colin!
