Regular Contributor II
Controller Issue
i have a Aruba 3600 controller with 172.16.0.0 vlan [vlan 1].[dhcp enabled]
Now i am implement another vlan [vlan 2] of 172.17.0.0 network assigned in port  3. [dhcp enabled]
now when i plug a ap in port 3 [vlan 2] its getting ip of 172.17.0.0 network and identify is master as 172.168.0.254. but controller cant show the ap.
vlan 1 = dhcp 172.16.0.0 network.
vlan 2 = dhcp 172.17.0.0 network.
please tell me now what i have do.
how can this ap broadcast ssid?
thanks in advance.
Re: Controller Issue
Change the IP address of your master :
interface vlan 1
no ip address
ip address dhcp-client
and then do controller-ip vlan 1
And in your AP System-Profile to IP it picked.
I suggest to use a static IP for your controller instead.
Thank you
Victor Fabian
Lead Mobility Architect @WEI
look my controller already have a static ip which is 172.16.0.254.
ap can recognise it as a master. But the problem is controller cant recognise the ap.
Ap on different vlan [vlan2 = 172.17.0.0]
controller on different vlan [vlan1=172.16.0.0]
in vlan 2 dhcp [172.17.0.0] working fine, it gives dynamic ip to ap.
Do you have CPSec enabled ? show control-plane-security
Have you installed licenses ? show ap license-usage
Thank you
Victor Fabian
yeah. the cpsec is on and all the licence is installed.
