mga
Occasional Contributor I
Converting AP 105 to IAP 105 ?
How do I do that?
Re: Converting AP 105 to IAP 105 ?
AFAIK, you can't.  You can convert an IAP-105 to an AP-105 (and then back to an IAP, if you want), but an AP that started life as an AP-105 can't ever be an IAP.
Moderator
No conversion possible from AP 105 to IAP 105 due to regulatory restrictions.
Shashi
Contributor II
So how do you convert an iap that is a rap back to iap?
Factory reset by holding the reset button while turning it on.
[ Edited ]
Just curious, what are the Regulatory Restrictions? difference between AP and IAP seems to be all software.
It does not work
I believe this refers to the different WLAN channels you can use in different areas of the world.
