- First connect both IAPs in the same Layer 2 segment (wired), disable Extend SSID.
- Once they form a cluster you can unplug the IAP that will acting as the Mesh Point
- Then just provide power to the Mesh point not a network connection and if is able to see the Mesh portal (backhaul iAP) it should be able to form the mesh link automatically no additional configuration.
