DHCP FINGERPRINT in IAP? When it will be supported?
  • 1.  DHCP FINGERPRINT in IAP? When it will be supported?
    Posted Apr 10, 2013 04:56 PM
    :smileyhappy:
    As far as i aware,the DHCP FINGERPRINT option isnt supported in Instant units yet. :smileysurprised:
    Can someone from Aruba advise, if in the future this function will be availble?  :smileyembarrassed:
    Thanks in advance.
    Me  :smileywink:
  • 2.  RE: DHCP FINGERPRINT in IAP? When it will be supported?
  • 3.  RE: DHCP FINGERPRINT in IAP? When it will be supported?
    Posted Apr 10, 2013 06:05 PM
    Thanks on gr8 info!
    :robottongue: Faster then mclaren F-1
