Distributed L3 DHCP scope Issues
I am trying to setup an VPN from IAP cluster that terminates on to a mobility controller. From what I read, Aruba recommends a distributed l3 dhcp scope with the virtual controller being the gateway and the DHCP server. However, for some reason I cannot get the IAP-VCto assign addresses when I configure a distributed l3 DHCP scope.
Here are the steps I have been taken:
Afterwords I try to connect to the SSID and cannot DHCP an address. From the IAP cluster I can ping the networks on the Controller thorugh the VPN.
Any thoughts?
Re: Distributed L3 DHCP scope Issues
Did you add the IAP MAC address to the controller RAP whitelist ?
Is the MAC address added to the IAP trusted list ?
Can you see the IAP when you run the "show IAP table" command ?
Can you please share how did you configured your scope?
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Victor,
Thanks for the reply.
It turns out that the IAP was not in the iap trusted db and only in the whitelist rap db.
Thanks for your help!
