Super Contributor I
FAP and HAP
Hello All,
Just want to find out can multiple FAP setup a GRE tunnel to the same HAP without load balancing enabled?
Normal Guy
Re: FAP and HAP
What is FAP and HAP?
Tim Cappalli | Aruba Security
Super Contributor I
Re: FAP and HAP
Home AP = AP to client is connect in the original cluster = HAP
foreign AP = AP in another cluster = FAP
Normal Guy
Valued Contributor I
Re: FAP and HAP
Super Contributor I
Re: FAP and HAP
Thanks Marcus. So with that disabled, each more than 1 FAP will establish a GRE tunnel each to the HAP?
Normal Guy
Re: FAP and HAP
Take a look at our online training videos here:http://cloud.arubanetworks.com/instant-training .
Scroll down and find module 13 "Roaming".  This is a short but informative video (13 min) but you can skip forward to about 8:30 for a discussion on Load Balancing and client behavior.
Super Contributor I
Re: FAP and HAP
Thanks Marcus. Had gone through it befor ejust to make usre I get the correct infromation.
Normal Guy
