Re: How can I turn AP to IAP
Yan Liu wrote:
If factory reset is not working, please share the following info from APBOOT:
Output of ?printenv'
Output of ?mfginfo?
Output of ?osinfo?
Also, another way of doing factory reset is the command ?factory_reset? in APBOOT.
However, I recommend against performing upgrade in APBOOT without clear instructions from Aruba.
Yan
apboot> PRİ   p
ping purgeenv printenv
apboot> printenv
bootdelay=2
baudrate=9600
autoload=n
boardname=Scapa
servername=aruba-master
bootcmd=boot ap
autostart=yes
bootfile=mips32.ari
ethaddr=6c:f3:7f:c2:06:9a
stdin=serial
stdout=serial
stderr=serial
ethact=eth0
Environment size: 206/65532 bytes
apboot> mfginfo
Manufacturing info:
System S/N : BU0032561
Date Code : 082512
Base MAC : 6c:f3:7f:c2:06:9a
MAC Count : 1
CPU Assembly : 0YY90KP0
CPU Major Rev : 11
CPU Brd Variant : 00
CPU Board S/N : YA2870A79
Country Code : UNRST
PROM Format : 1
Checksum : 90
apboot> osinfo
Partition 0 does not contain a valid OS image
Partition 1 does not contain a valid OS image
Constantin wrote:
emrekoca wrote:
Unit is originaly IAP-92, I want to turn back to IAP-92 again. There is nothing to do with RAP.
use the purgeenv command the sequence would be as follows :
purgeenv
saveenv
boot
Hit <Enter> to stop autoboot: 0
apboot>
apboot> purgeenv
Un-Protected 1 sectors
.done
Erased 1 sectors
Writing
apboot> saveenv
Saving Environment to Flash...
.done
Erased 1 sectors
Writing
apboot> boot
Checking image @ 0xbf100000
Invalid image format version: 0xffffffff
Checking image @ 0xbf800000
eth0 up: 1 Gb/s full duplex
DHCP broadcast 1
DHCP broadcast 2
DHCP broadcast 3
DHCP broadcast 4
DHCP broadcast 5
Trusted Contributor I
did that resolve it for you?
I upraded with new IAP image.
Thats wonderful that you solved it by upgrading the image! Exactly how did you do this? I am having the exact same problem, could you perhabs do a step by step solution and/or link me in the right direction? Many thanks!
factory_reset command should have worked for you instead of purgeenv from the console.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Regular Contributor I
make sure to flash the correct partition , as the IAP has partiiton_1 containing "always" the IAP OS , and partition0 containing a copy from it , and can be temporarily flashed with controller-based flash for the IAP to be running as AP .
i had once the same problem and i had to setenv the correct partition and then i was able to recover or reflash .
apboot> printenv
bootdelay=2
baudrate=9600
autoload=n
boardname=Scapa
bootcmd=boot ap
autostart=yes
bootfile=mips32.ari
ethaddr=24:de:c6:c1:c2:52
stdin=serial
stdout=serial
stderr=serial
ethact=eth0
apboot> mfginfo
Manufacturing info:
System S/N : BU0152828
Date Code : 100913
Base MAC : 24:de:c6:c1:c2:52
MAC Count : 1
CPU Assembly : 0AR50KP0
CPU Major Rev : 10
CPU Brd Variant : 01
CPU Board S/N : R539O0974
PROM Format : 1
Checksum : c9
apboot> osinfo
apboot> purgeenv
.done
Erased 1 sectors
Writing
apboot> saveenv
.done
Erased 1 sectors
Writing
apboot> boot
Invalid image format version: 0x0
eth0 down
DHCP broadcast 1
eth0 down
DHCP broadcast 2
eth0 down
DHCP broadcast 3
eth0 down
DHCP broadcast 4
eth0 down
DHCP broadcast 5
eth0 down
It does not look like ethernet0 is plugged into anything.
