How do I add IAP 215 to 105 network
  • 1.  How do I add IAP 215 to 105 network
    Posted Dec 04, 2015 10:00 AM
    Hi
    I have 4 new IAP 215 APs and I would like to add them to an exsisting IAP 105 network. All APs are the same region however the 215s have a slightly lower firmware version. Unfortauntly I can't find the firmware to upgrade the 215s. I have tried running check for new version in the GUI but it just gives me received no response from server. Any have any ideas. The firmware versions are
    215 - 6.4.2.0-4.1.1.0_46028
    105 - 6.4.2.6-4.1.1.0_51810
  • 2.  RE: How do I add IAP 215 to 105 network
    Posted Dec 04, 2015 10:02 AM
    jcrowhurst,
    Please PM me and I will send you images for both.
  • 3.  RE: How do I add IAP 215 to 105 network
    Posted Dec 04, 2015 11:09 AM
    Thank you so much for the correct firmware versions. Having updated all the IAPs I know have a fully working network again with all IAPs showing in the GUI and working with the correct details from the IAP 105s.
