How does the second AP associated wih the same WLAN in IAP?
  • 1.  How does the second AP associated wih the same WLAN in IAP?
    Posted Jul 01, 2014 11:45 AM
    I configured the first AP like virtual controller. I edit "Virtual controller IP" and I edited the AP menu to change "enabled" in prefered master. I created a SSID test.
    Then I connected in the same switch the second acces point and what I should do for to see each other?
    Thanks for all,
  • 2.  RE: How does the second AP associated wih the same WLAN in IAP?
    Posted Jul 01, 2014 12:20 PM
    Is the wired port in the same VLAN?
    Also, make sure auto-join is enabled.
  • 3.  RE: How does the second AP associated wih the same WLAN in IAP?
    Posted Jul 01, 2014 03:20 PM
    You'll also need to make sure they're both running the same OS version.
  • 4.  RE: How does the second AP associated wih the same WLAN in IAP?
    Posted Jul 01, 2014 05:40 PM
    If the second iAP comes up on the same VLAN as the first, it will see that there is another iAP already up and in-charge.
    It will then check software version and pull a copy of the software from the first iAP (as long as it's a compatible model) and self up/down-grade prior to joining the cluster.
    Are you not seeing new iAP join the cluster auto-magically?
