How to upgrade IAP using airwave?
This thread has been viewed 28 times
  • 1.  How to upgrade IAP using airwave?
    Posted Feb 26, 2018 06:13 PM
    I would like to upgrade the firmware on our IAP-315 network. We use airwave for config and the instructions on how to do the firmware upgrade are a little unclear.
    I've uploaded the firmware to the airwave server (is this required?) but I'm not sure about the settings on the following image.
    Do I need to set a firmware file server?  Enforce Group Firmware Version?
    I can I simply select from the droplist next to Aruba Instant Virtual Controller, and click "Save and Upgrade Devices" ?
  • 2.  RE: How to upgrade IAP using airwave?
    Posted Feb 27, 2018 05:42 AM
    1.  Upload firmware for that device under  Upload Firmware and Files
    2.  Choose the Enforce Option and select the desired firmware version from the dropdown.
    3.  Your devices should upgrade or downgrade immediately.
  • 3.  RE: How to upgrade IAP using airwave?
    Posted Feb 27, 2018 06:21 AM
    thanks Colin.  Do I need to use only a local version which I have uploaded or can I select options from the image server category in the drop list?
