IAP-103 VC with web categorization
  • 1.  IAP-103 VC with web categorization
    Posted Mar 22, 2016 06:49 AM
    Hi Folks,
    A customer is using a few IAP-103 with the integrated web categorization.
    Unfortunately it's not working how I expected. I checked the proxy and firewall settings and everything should be ok now.
    Which service are the IAP-103 using for web-categorization? Is it OpenDNS or Brightcloud? I don't have an OpenDNS account configured in the IAP.
    When I have a web-category rule running, the clients can't open any webpage. First  it looked like the AP can't connect to Brightcloud, but now I'm not sure anymore.
    Is it a problem with the connection to the cloud or could it be a subscription problem?
    Any ideas on this? Do I need a active subscription for one of these? The pricelist and datasheet isn't telling very much about it.
    Version is 6.4.3.4
    Regards
  • 2.  RE: IAP-103 VC with web categorization
    Posted Mar 22, 2016 07:08 AM
    It needs to be able to reach aruba.brightcloud.com using port 443
    http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-filter-Web-traffic-for-WLAN-clients-using-Web-Category/ta-p/234036
    No subscription needed
  • 3.  RE: IAP-103 VC with web categorization
    Posted Nov 29, 2016 03:02 AM
    Is this information still valid, I mean: no subscription needed ?
    What about the future ?
    rgrds.
    Zbigniew Grabis
