Skip to main content (Press Enter).
Register | Sign in
Skip auxiliary navigation (Press Enter).
Skip main navigation (Press Enter).
Toggle navigation
Discussion
Support
Aruba Documentation Portal
Aruba Support Knowledge Base
Community Learning
News
ACEX Hall of Fame
MVP Overview
Tech Corners
Search
Community Home
Discussion
Topic Thread
Community Home
Discussion
31K
Library
937
Events
0
Members
1.6K
Back to discussions
Expand all
Collapse all
IAP-103 with Cisco 2960X - Port flapping (Solution)
1.
0
Kudos
vass
Posted Apr 19, 2017 06:50 AM
Reply Privately
Options Dropdown
Just sharing some info for future reference. After upgrading from Cisco switchs 3560 to 2960X we saw that some ports that were connected to the IAP´s started flapping. After a lot of debug and trial and error configs to no avail i found a reported Cisco bug (
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCus35889/?referring_site=bugquickviewclick
) for this platform (not for my IOS, but cisco never fixed it so it is probably present in all 15.x IOS). The fix is to use the "no power efficient-ethernet" command at the switch ports.
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Privacy policy
Terms of service
Site Map
Legal
© Copyright 2024 Hewlett Packard Enterprise Development LP
All Rights Reserved.
Powered by Higher Logic
