IAP-103 x IAP-105
  • 1.  IAP-103 x IAP-105
    Posted Aug 27, 2014 03:54 PM
    The IAP-103 has better hardware compared to IAP-105? In theory the IAP-103 would support higher density than 105?
    Paulo Raponi
  • 2.  RE: IAP-103 x IAP-105
    Posted Aug 27, 2014 04:12 PM
    The 103 is meant for low density environments.  If you are looking at a choice with the 105, consider the IAP-205 which has the same list price as the 105 and is 11ac capable.
  • 3.  RE: IAP-103 x IAP-105
    Posted Aug 27, 2014 04:37 PM
    When do the iAP 205 start to ship?
  • 4.  RE: IAP-103 x IAP-105
    Posted Sep 22, 2014 10:30 AM
    When do the IAP-205/215s start to ship?
  • 5.  RE: IAP-103 x IAP-105
    Posted Sep 22, 2014 03:57 PM
    The IAP-20x and IAP-21x are orderable and have begin shipping in limited quantities.  This will ramp up  over the next few weeks.
