IAP 105 and IAP 305
  • 1.  IAP 105 and IAP 305
    Posted Nov 27, 2017 10:24 AM
    Can I add 9 IAP 305's to an existing 7 IAP 105 CLuster? Thanks.
  • 2.  RE: IAP 105 and IAP 305
    Posted Nov 27, 2017 10:59 AM
    Unfortunately you cannot, because support for IAP-105s was ended with 4.3.0.0:
    http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Command/Core_Download/Default.aspx?EntryId=24557
    The minimum version of software for the IAP-305 is 4.3.1.0
    http://www.arubanetworks.com/assets/ds/DS_AP300Series.pdf
  • 3.  RE: IAP 105 and IAP 305
    Posted Nov 27, 2017 01:15 PM
    You could add a controller and convert the IAP-105s to AP-105.
    AP-105 is still supported on the most recent AOS version, so it can coexist with AP-305 in a controller-based deployment..
  • 4.  RE: IAP 105 and IAP 305
    Posted Nov 28, 2017 02:46 AM
    Thanks for the info guys, I really appreciate your help, I'd love to get a controller etc but money is a too tight, would IAP 205's be compatible?
  • 5.  RE: IAP 105 and IAP 305
    Posted Nov 29, 2017 02:35 PM
    Yes, 205s are compatible.
    Min versions for 205 is 4.1.1.0
    Last supported version for 105 is 4.2
  • 6.  RE: IAP 105 and IAP 305
    Posted Nov 29, 2017 03:17 PM
    Just be aware that end-of-sale of the IAP-205 has been annouced (effective 5/1/2018).
