last person joined: 10 hours ago
IAP 205 RW Temperature
  • 1.  IAP 205 RW Temperature
    Posted Dec 22, 2016 08:59 AM
    Hello, I'm currently testing the IAP 205 RW in order to deploi more tha  100 Stores with Wifi services.
    Since two days that  put it ON, I noticed that the temperature is really higth more that 60°C, is that normal? if not what can I do to drecreasse it temperature?
    Thanks in advance,
  • 2.  RE: IAP 205 RW Temperature
    Posted Dec 22, 2016 09:31 AM
    How do you have it mounted?
  • 3.  RE: IAP 205 RW Temperature
    Posted Dec 22, 2016 09:42 AM
    with a PoE injector only
  • 4.  RE: IAP 205 RW Temperature
    Posted Dec 22, 2016 09:44 AM
    I mean is it mounted on the ceiling or the wall?  Where is it?
  • 5.  RE: IAP 205 RW Temperature
    Posted Dec 22, 2016 11:15 AM
    I have not mounted it yet, is in my desk, dou you believe that is a factor?
    How works its internal ventilation system?
  • 6.  RE: IAP 205 RW Temperature
    Posted Dec 22, 2016 11:53 AM
    It requires airflow to cool itself, so putting it on the ceiling, where there is airflow will cool it.  In addition, there is a heat sink in the AP which is where all the heat is drawn.  It is not meant to be touched.  Please try mounting it on the ceiling and the airflow should cool it.
