Occasional Contributor I
IAP 205 using wifi uplink
Does anyone know how to enable it? - Im facing greate trouble with it.
http://www.arubanetworks.com/techdocs/InstantHTML/Content/Chapter9%20Uplink%20Configuration/ConfigureWiFIUL.htm
 Followed this guide
Re: IAP 205 using wifi uplink
WiFi Uplink isn't supported on 11ac APs.
Thank you,
Vijay Rajasimhan | Principal Network Engineer
Customer Advocacy | Aruba Networks
Did something you read in the Community solve a problem for you? If so, click "Accept as Solution" in the bottom right hand corner of the post.
So to extend the wireless signal, i need to purchase some new iaps?
What i need is to extend the Wireless signal where i dont have access to a wired port - i have been looking in to mesh, but i dont think it will work like i want.
/Nikolaj
Yes. This is called wireless mesh.
Tim
Tim Cappalli | Aruba Security
I have tried to setup mesh on two IAP-205-RW, but cant get it working.
Im also using af POE adapter to get it powered up, i dont know if that could be the cause why it isnt working.
When setting up Mesh i followed the steps in the userguide: "Setting up Instant Mesh Network" - but when i come to the step where i should disconnect my AP, it isnt working - its just rebooting and the light is yellow in 2,4/5ghz - i was wondering if i need to use a power adapter insted of the POE-Adapter?
It also says in the guide "Mesh is by default disabled" - how do i enable it?
/Nikolaj
Please see here:  http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-Configure-a-basic-Instant-mesh/ta-p/205027
Go straight to the section "
New Mesh Provisioning Procedure in 4.1
So if im correct, mesh is NOT working on 11AC platforms?
  1. All 11AC platforms, e.g. IAP22x (Ardmore), IAP27x(k2);
npabst,
I apologize.  I should have looked at the model of your access point.  Mesh Does work in IAP 4.2.0.0 and above for 802.11ac access points.
Its okay, but could i be a problem that im using a POE-adapter? Or should i use a normal power adapter, so I dont use the ethernet port.
And how do I enable the MESH portal?
World it work with only two Aps?
You can either use a POE injector or power adapter
For mesh, the same instructions in the article here apply (Instant 4.1 and above):  http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-Configure-a-basic-Instant-mesh/ta-p/205027
It would work with only 2 APs, yes.
