last person joined: 9 hours ago
IAP 205 vlan and device onboard
  • 1.  IAP 205 vlan and device onboard
    Posted Sep 16, 2016 07:22 AM
    Hi guys,
    with ClearPass I already done several times vlan or device tag. Meaning if a device is type android and vlan is x , I send them to a role that i created.
    Is it possible to do that on a virtual controller without Clearpass? Devices like android and belonging to a specific vlan add a different role.
    I read that identifying  device OS types could be only done with CPPM, but as I see that IAP VC identifies the devices, I have this dought..
    Regards
    Regards
  • 2.  RE: IAP 205 vlan and device onboard
    Posted Sep 16, 2016 07:24 AM
    Yes you can. Same setup.
  • 3.  RE: IAP 205 vlan and device onboard
    Posted Sep 16, 2016 07:30 AM
    But without Clearpass? Client does not have Clearpass..
    Where can I tell if a device is an android and comes from vlan x goes to role A?
    Regards
  • 4.  RE: IAP 205 vlan and device onboard
    Posted Sep 16, 2016 07:33 AM
    Sorry, saw "Onboard" and misunderstood. If not ClearPass, what RADIUS server are you using?
  • 5.  RE: IAP 205 vlan and device onboard
    Posted Sep 16, 2016 08:04 AM
    Hi
    I am just seeking information on what Radius we used at the client for config an SSID "corporate" , that uses radius users to authenticate.
    I will brief you shortly..
  • 6.  RE: IAP 205 vlan and device onboard
    Posted Sep 16, 2016 10:50 AM
    Got It
    One windows for windows authentication and a tek radius for mac authentication.
    Is this scenario is it possible to choose based on device and vlan? like in Clearpass?
    Regards
  • 7.  RE: IAP 205 vlan and device onboard
    Posted Sep 19, 2016 05:26 AM
    One Radius for windows authentication and a tek radius for mac authentication.
    In this scenario is it possible to choose based on device and vlan? like in Clearpass?
    Or the cleanner way is to have ClearPAss?
    I also saw a document in airheads , using dhcp fingerprint, but seemed confused and not "clean".
    Regards
  • 8.  RE: IAP 205 vlan and device onboard
    Posted Sep 21, 2016 06:08 AM
    Hi
    Is this the wright conclusion?
    Regards
  • 9.  RE: IAP 205 vlan and device onboard
    Posted Sep 21, 2016 06:15 AM
    What kind of authentication are you using?
  • 10.  RE: IAP 205 vlan and device onboard
    Posted Sep 21, 2016 08:29 AM
    Hi
    I am using 802.1x with radius server
