IAP 205h does not boot
New IAP 205H out of the box does not boot. It's stuck in a boot cycle. Tera-term in and watch the boot process - it reboots at the same spot every time. Screen shot attached.
Anyone have similar issue?
Contributor II
Re: IAP 205h does not boot
Looks like AP-205H instead of IAP-205H to me from the screenshot provided.
Sometime AP (not sure about IAPs) stucks if it cannot get the IP Address. Can you make sure your DHCP Server is working fine.Try to work with static IP assignment.
Also, re-check your AP model whether it is instant or not.
Jibran Aziz
ACDX | ACCP | ACMP | ACMA | CCIE (RnS, SP, DC) | JNCIS | JNCIA
