IAP-275 Power Cords
Aruba is charging $200+ for a power cable and plastic connector.  Has anyone found an alternate source for this cable?
Frequent Contributor II
Re: IAP-275 Power Cords
When you say it like that it sounds outrageous but aren't you getting a 802.3at power injector with that power cable and piece of plastic?
I know you can get a low end poe+ switch for less than that which could help if you are powering more than one 275.
-Rosie
We'll be installing several IAP-275 in a mesh configuration.  Only the first will be powered by POE.  Each additional device will be powered independently and need a power cord.
mesh support is not available yet with IAP-2XX series instant APS.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
look at the 4.1.1.7 release notes for details
ACDX #420 | ACCA
The mesh firmware is in beta and scheduled to be released soon, so I've been told.  Plus the beta firmware is available for download if someone can't wait.
This doesn't change the neccessity of having a power cord or the cost.
What does 4.11 release notes say?
you are correct it will be release sometime later on no eta. it says pretty much what I wrote a couple of posts above. I know mesh works on other models because I've tested it just not on 2xx series.
ACDX #420 | ACCA
From the 6.4.2.6-4.1.1.7 release notes.
ACDX #420 | ACCA
