Aruba
IAP 3.3 Code
Release 3.3 of the IAP code stream was published this week. Notably included in this release is the ability to redirect to an external captive portal via https which was previously not possible.
In reviewing this for a few deployments, it was isolated that if clients want to whitelist any HTTPS sites, they should use the pre-auth ACL role configuration to allow HTTPS, instead of using the manual white list feature. The manual whitelist of the walled garden only supports HTTP, not HTTPS (because there is no such thing as a transparent HTTPS proxy) Therefore, the only way to white list HTTPS sites would be through the ACL level.
Check out the release notes, lots of other new goodies in there as well.
Code is on the support site.
Adam
| Adam Kennedy, Systems Engineer - adamk@hpe.com
| Service Providers – Aruba, an HPE Company
| Twitter: @adam8021x | Airheads: akennedy
Valued Contributor I
Re: IAP 3.3 Code
As a follow-on, v3.3 is available for download on the TAC site only at the moment.
New releases typically take 3 - 6 weeks to appear on the cloud-based upgrade servers (which is what the "Check for Updates" button uses).
New releases also take around a month to show up for the Dell branded versions of IAP.
Aruba
Re: IAP 3.3 Code
Ahh! right you are Marcus, got excited reading the notes! :)
