IAP Firmware Issue
Hi All,
I need the Latest firmware for IAP model 103 its very urgent. if anyone is having please share asap.
Thanks & Regards
Sonu Tripathi
Re: IAP Firmware Issue
Hi All,
Please help me if you have  AP Class  "Pegasus"  latest firmware plese share its very urgent.
I need to upgrade the firmware beacuse its running on the firware version 6.4.0.2-4.1.0.0_44004 and in this version its not broadcasting the ssid.
Please share
Thanks & Regards
Sonu Tripathi
Hi Please send me a valid downloadabe file. This file is not working
Those are the valid images. If you're having issues, contact Aruba TAC.
Tim
Tim Cappalli | Aruba Security
Tim is correct but if it is not broadcasting an SSID, what regulatory domain have you chosen?
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACMP
[If you found my post helpful, please give kudos!]
yes issue got resolved when i changed the country code as JAPAN (JP3) in other regularity domain it was not working...
Thanks & Regards
Sonu
