last person joined: 11 hours ago
IAP VPN: Centralized L2 remote client connectivity issue
  • 1.  IAP VPN: Centralized L2 remote client connectivity issue
    Posted Jun 01, 2017 09:40 AM
    I'm setting up IAP VPNs with L2 centralized scopes. Now, everything is working fine except that the remote clients (aka printers, laptops and others) are not reachable from the corporate (datacenter) network. The datacenter however, is perfectly reachable from the remote site.
    I can ping the remote clients from their default gateway or any other L3 on the router but with a computer or other device in L2 or L3, reachability is non existent.
    In a packet capture, I see the remote client is receiving ARP requests when it is not working. But that is about it.
    Any ideas?
    Kind regards,
    jcelis
  • 2.  RE: IAP VPN: Centralized L2 remote client connectivity issue
    Posted Jun 01, 2017 09:46 AM
    situation:
    local client (LC): 192.168.1.10
    local gateway (LG): 192.168.1.1
    vpn gateway (VG): 10.10.10.1
    remote client: (RC): 10.10.10.10
    Ping:
    LC-LG = OK
    LG-RC = OK
    VG-RC = OK
    LC-RC = not OK
    RC-LC = OK
    RC-VG = OK
