IAP-VPN failover to other IAP
hi all,
In instant IAP-VPN, we can have IPsec tunnel to main controller. If master IAP goes down and another IAP becomes master, will IPSec tunnel remains up or it will re-establish ?
If it re-establishes, is there anyway to minimize the downtime like having second IPSec tunnel from a backup IAP. So far in my research i am almost sure that there is no concept of backup IAP, but please correct me if i am wrong.
Re: IAP-VPN failover to other IAP
Yes it will re-establish. If you have a second controller, you can create a backup IPSec to that controller.
Tim Cappalli | Aruba Security
I don't have the second controller but please also elaborate on other points like is there a possibility of having a backup IAP to minimize the downtime ?
If not, how much time does it takes to re-establish ? also is it a good design ?
Best Regards
Ovais Iqbal
It takes a few seconds. Most users won't even notice.
