last person joined: 3 hours ago
IAP convert to Camp AP without Lic AP in controller
  • 1.  IAP convert to Camp AP without Lic AP in controller
    Posted Feb 15, 2017 09:29 PM
    Hallo All,
    I have some question about converting IAP:
    Can IAP convert to Campus AP without Lic AP in controller?
    Can IAP convert to Camp AP with ArubaOs in controller 6.3.xx and IAP 6.4.x.x?
    Thank You
  • 2.  RE: IAP convert to Camp AP without Lic AP in controller
    Posted Feb 16, 2017 05:11 AM
    What model of IAP is it?
  • 3.  RE: IAP convert to Camp AP without Lic AP in controller
    Posted Feb 16, 2017 05:43 AM
    Hello James,
    In the firts question, i got a answear from other post.
    So you can help me on second question.
    I have IAP-215-RW
  • 4.  RE: IAP convert to Camp AP without Lic AP in controller
    Posted Feb 16, 2017 05:46 AM
    Thank You
    No. MINIMUM SOFTWARE VERSIONS for AP215 is ArubaOS 6.4.2.0 as per the datasheet.
