Regular Contributor II
IAP interference issue.
Hi all,
In one of my client place, they are facing interference issue with IAP 105.
Result :- extremly slow network.
Please give me some suggestion on how to minimize interference.....
I attached two screenshot here regarding this issue.
Re: IAP interference issue.
You have a large number of SSIDs. Are all of these enabled on most of the APs?
Tim Cappalli | Aruba Security
Yeah all are enabled.
Is there the problem coming from ?
More SSIDs= more traffic=reduced throughput.
Show us the page with the AP Utilization on it.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
But most of the user use that corp SSID  [Myconnect+].
And rest of are not so much used
Those SSIDs are still beaconing at the lowest rate, and that creates traffic utilization:
Please see this traffic calculator by Andrew Von Nagy here:  http://www.revolutionwifi.net/blog/p/ssid-overhead-calculator.html
In addition, if those SSIDs share a VLAN, copies of each broadcast are sent to all of those SSIDs.
Thanks cjoseph.
i'll give a try in tomorrow morning.
BTW they are facing sticky client issue also. [client match and clent aware both are enabled]
Another big problem that you have is that you are bonding channels on the 2.4ghz side.  That by itself will cause massive  interference.  You need to Disable Wide channel bands before your network melts:
If you are having roaming issues, you need to make sure that the ARM min is as 12 and maximum at 18 to start.  Clientmatch does not help roaming.  It tries to help after the client has already roamed, but getting the maximum and minimum power correct is crucial for roaming to work properly BEFORE clientmatch works.
Thanks for your reply.
could you please tell me where can i disable this wide channel bands.
some doc regarding this will be helpfull
