Hi All,
I am configuring controller based wireless solution. I am having 6 IAP 105 and a 620 controller.
First I connected all IAPs to controller ( no uplink to controller), controller has DHCP server 172.16.0.0./24 network.Then from GUI of IAP - Virtual Controller
I selected CONVERT tab and put IP of controller..after that all IAPs are converted to Controller managed campus AP.
Q.1 while connecting IAPs what if i connect all IAPs at a time..? will there be any issue of virtual controller selection..?
Now I have APs (Converted version of IAPs) having controller IP as 172.16.0.254 as they have got IP from Controller DHCP.
I changed controller IP to 192.168.1.0/24 and connected the Uplink to network switch..our network is flat network with only VLAN 1 and network has DHCP server. after that I connected all APs to controller directly but they didnt come up...Q.2 Is this Normal.
Then I factory_reset all APs..on virtual controller-iap GUI I did the same conversion thing now with controller IP as 192.168.1.2...
All aps are up with controller but after 10-12 hours 2 of them stopped working..I dont know what has happened as no config changes are done...APs are rebooting continuosly...how to troubleshoot this as I controller GUI showing APs as down.
I have got logs.tar file from controller...what might be the cause of this issue...???
