Regular Contributor I
IAP to Clearpass configuration help
I am looking for a solution to the following problem:
My guest SSID vlan is fed by a cablem modem and therefore is not routable by the corporate network.  Because of this, there is no way for a guest user to access a captive portal page hosted via clearpass.  I get around this on my campus network by building a layer 3 GRE tunnel from the controller to clearpass.  I am looking for a similar solution for IAP to clearpass for my remote sites.  I see that IAP supports GRE but it appears this is only a layer 2 tunnel.  Has anyone else run into this problem?
Re: IAP to Clearpass configuration help
Make your ClearPass box a public page, so that all of your clients can access it.
I assume you are saying publish the portal page to the internet which is not really an option.
