IAP105 led status
  • 1.  IAP105 led status
    Posted Jan 19, 2016 07:44 PM
    I've got 3 IAP105s setup and working. However, the LEDs on the units are not lit up. When they boot, the go through the LED sequence of blinking green while booting, red for not "up", but once everything is settled they turn off. Is this normal? How can I get them to stay on?
  • 2.  RE: IAP105 led status
    Posted Jan 20, 2016 04:09 AM
    That is probably the option 'LED display' under System -> General -> Advanced Options:
    If disabled, the LEDS will turn of when the AP has succesfully booted. Default setting is 'Enabled', so someone should have changed that in your deployment.
