Infusion Pump not able to connect
  • 1.  Infusion Pump not able to connect
    Posted Dec 23, 2015 07:57 AM
    Hi All.
    i have an issue with my medicale wifi device " Infusion Pump'' this  devive is not able to connect with my SSID for medicle deiveces it is able to connect with other SSIDs . what could be the resion .
    waqar.
    i have aruba conntroller 6000 and APs 105 .
  • 2.  RE: Infusion Pump not able to connect
    Posted Dec 23, 2015 08:40 AM
    What kind of SSID is it?  WEP, WPA2-PSK?
    What are the settings?  Type "show wlan ssid-profile <name of your ssid>" and print the output here.
  • 3.  RE: Infusion Pump not able to connect
    Posted Jan 01, 2016 07:28 PM
    What encryption and authentication method is in use on the SSID?
    Sent from Nine
