We had a power outage last week. Somehow it message with the Aruba PoE switch we had, and most likely the wireless controller as well. We performed several troubleshooting tasks, but eventually just had to wipe out the conifguration on the switch. Another tech rebuilt the configuration and we now have Internet access if you are plugged in with a cable. However, the Aruba 105 IAPs are not broadcasting SSIDs now and the controller can't find them. I am sure it has something to do with the fact that the switch the controller is connected to has been re-configured, but it should have almost identitical properties as before (same VLANs, etc.).
Here's what I have:
Aruba S3500-24P PoE switch
Aruba 650 wireless controller.
The address of the controller from the documentation I have is 10.116.0.5. I cannot ping that even if I am connected directly to the ports on the controller. When I am plugged in with a UTP cable, I get a DHCP IP address of 10.116.13.XXX, so I know there is communication happening between the controller and the switch somehow. The IAPs are also showing IP addresses on the same network. The only way to access the web interface of the controller is to set a static IP address on the same network (10.116.0.XX).
I am very new to Aruba products, but it feels somewhat similar to Cisco, so I can feel my way around a little bit.
Anyway, I plugged into an AP's console port and here is the output (Any names with XXX... is to provide at least some anonymity to the network):
APBoot 1.0.9.12 (build 22797)
Built: 2009-11-04 at 15:53:54
Model: AP-10x
CPU: AR7161 revision: A2
Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
DRAM: 128 MB
POST1: passed
Copy: done
Flash: 16 MB
PCI: scanning bus 0 ...
dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
00 00 168c 0029 00002 01 10000000 00000000 00000000 00000000
01 00 168c 0029 00002 01 10010000 00000000 00000000 00000000
Net: eth0
Radio: ar922x#0, ar922x#1
Hit <Enter> to stop autoboot: 0
Checking image @ 0xbf100000
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
ELF file is 32 bit
Loading .text @ 0x80e00000 (3768408 bytes)
Loading .data @ 0x81198060 (32 bytes)
Clearing .bss @ 0x81198080 (16 bytes)
## Starting application at 0x80e00000 ...
Uncompressing...................................
ú
Aruba Networks
ArubaOS Version 6.1.3.4-AirGroup (build 35647 / label #35647)
Built by p4build@stan on 2012-10-08 at 12:50:26 PDT (gcc version 4.3.3)
CPU Rev: aa
71x CPU
Flash variant: default
Cache parity protection disabled
Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
Memory: 122880k/131072k available (1850k kernel code, 8088k reserved, 681k data, 2952k init, 0k highmem)
detected lzma initramfs
initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=12341760
LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> .............................................................................................................................................................................................
AR7100 GPIOC major 0
wdt: registered with refresh
Enabling Watchdog
Talisker RSSI LED initialization
Creating 1 MTD partitions on "ar7100-nor0":
0x00000000-0x01000000 : "flash"
i2c /dev entries driver
i2c-talisker: using default base 0x18040000
AD7416 driver probing for devices on AR7100 I2C
.<6>lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
Starting Kernel DES KAT ...Completed Kernel DES KAT
Starting Kernel AES KAT ...Completed Kernel AES KAT
Domain Name: arubanetworks.com
No panic info available
Testing TPM... Passed
ag7100_mod: module license 'unspecified' taints kernel.
AG7100: Length per segment 512
AG7100: Max segments per packet 4
AG7100: Max tx descriptor count 400
AG7100: Max rx descriptor count 252
AG7100: fifo cfg 3 018001ff
AG7100CHH: Mac address for unit 0
AG7100CHH: d8:c7:c8:c2:69:1a
ATHRF1: Port 0, Neg Success
ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
AP xml model 39, num_radios 2 (jiffies 4153)
init_asap_mod: installation:0
radio 0: band 1 ant 0 max_ssid 8
radio 1: band 0 ant 0 max_ssid 8
setting bond0 as bridge child
setting gre0 as split child
Starting watchdog process...
Getting an IP address...
ag7100_ring_alloc Allocated 4800 at 0x813b0000
ag7100_ring_alloc Allocated 3024 at 0x813a6000
AG7100: cfg1 0xf cfg2 0x7014
ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
AG7100: unit 0: phy not up carrier 1
Writing 4
ADDRCONF(NETDEV_UP): bond0: link is not ready
AG7100: unit 0 phy is up...RGMii 1000Mbps full duplex
AG7100: pll reg 0x18050010: 0x110000 AG7100: cfg_1: 0x1ff0000
AG7100: cfg_2: 0x3ff
AG7100: cfg_3: 0x18001ff
AG7100: cfg_4: 0xffff
AG7100: cfg_5: 0xfffef
AG7100: done cfg2 0x7215 ifctl 0x0 miictrl 0x22
ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
10.116.13.7 255.255.248.0 10.116.8.1
Running ADP...cat: /tmp/master: No such file or directory
Done. Master is
killall: nanny: no process killed
killall: sapd: no process killed
Sending SIGKILL to all processes.
Please stand by while rebooting the system.
___________________________________________________________________
Here are some lines from the "Show run..." command on the controller:
vlan range 2 wired aaa-profile "XXXX-aaa_prof"
vlan 3 wired aaa-profile "XXXX-WEP-aaa_prof"
vlan 4 wired aaa-profile "XXXXGuest-aaa_prof"
vlan-name XXXX-Trusted pool
vlan XXXX-Trusted 2-3
vlan-name XXXX-Untrusted pool
vlan XXXX-Untrusted 4
interface gigabitethernet 1/0
description "GE1/0"
trusted
trusted vlan 1-4094
interface gigabitethernet 1/1
description "GE1/1"
trusted
trusted vlan 1-4094
interface gigabitethernet 1/2
description "GE1/2"
trusted
trusted vlan 1-4094
interface gigabitethernet 1/3
description "GE1/3"
trusted
trusted vlan 1-4094
interface gigabitethernet 1/4
description "GE1/4"
trusted
trusted vlan 1-4094
interface gigabitethernet 1/5
description "GE1/5"
trusted
trusted vlan 1-4094
switchport mode trunk
interface gigabitethernet 1/6
description "GE1/6"
trusted
trusted vlan 1-4094
interface gigabitethernet 1/7
description "GE1/7"
trusted
trusted vlan 1-4094
interface vlan 1
ip address 10.116.0.5 255.255.255.0
ip default-gateway 10.116.8.1
no uplink wired vlan 1
uplink disable
ip dhcp excluded-address 192.168.99.1 192.168.99.10
ip dhcp excluded-address 192.168.98.1 192.168.98.10
ip dhcp excluded-address 192.168.97.1 192.168.97.10
ip dhcp excluded-address 192.168.96.1 192.168.96.10
ip dhcp excluded-address 192.168.96.253 192.168.96.254
ip dhcp pool DHCP-999
default-router 192.168.99.1
dns-server 10.116.12.41 10.116.12.49
domain-name XXXXXXX
lease 0 8 0 0
network 192.168.99.0 255.255.255.0
authoritative
ip dhcp pool DHCP-998
default-router 192.168.98.1
domain-name XXXXXXX
lease 0 8 0 0
network 192.168.98.0 255.255.255.0
authoritative
ip dhcp pool DHCP-997
default-router 192.168.97.1
dns-server 4.2.2.1 4.2.2.2
lease 0 4 0 0
network 192.168.97.0 255.255.255.0
authoritative
ip dhcp pool DHCP-996
default-router 192.168.96.1
lease 0 4 0 0
network 192.168.96.0 255.255.255.0
authoritative
service dhcp
____________________________________________________________________
Now from the switch:
ip-profile
default-gateway 10.115.0.161
controller-ip vlan 1
lcd-menu
interface-profile ospf-profile "default"
area 0.0.0.0
interface-profile pim-profile "default"
interface-profile igmp-profile "default"
stack-profile
ipv6-profile
interface-profile switching-profile "default"
interface-profile switching-profile "XXXXUpstream"
access-vlan 6
native-vlan 6
interface-profile switching-profile "Trunk"
switchport-mode trunk
access-vlan 10
native-vlan 10
interface-profile switching-profile "Upstream-profile"
access-vlan 10
native-vlan 10
interface-profile switching-profile "VLAN10"
access-vlan 10
native-vlan 10
interface-profile poe-profile "default"
interface-profile poe-profile "poe-factory-initial"
enable
interface-profile enet-link-profile "default"
interface-profile lldp-profile "default"
interface-profile lldp-profile "lldp-factory-initial"
lldp transmit
lldp receive
med enable
interface-profile mstp-profile "default"
interface-profile pvst-port-profile "default"
vlan-profile mld-snooping-profile "default"
vlan-profile igmp-snooping-profile "default"
vlan-profile igmp-snooping-profile "igmp-snooping-factory-initial"
spanning-tree
mode mstp
gvrp
mstp
lacp
vlan "1"
vlan "6"
description "VLAN0006"
vlan "10"
description "VLAN0010"
vlan "20"
description "VLAN0020"
interface gigabitethernet "0/0/0"
interface gigabitethernet "0/0/1"
interface gigabitethernet "0/0/2"
interface gigabitethernet "0/0/3"
interface gigabitethernet "0/0/4"
interface gigabitethernet "0/0/5"
interface gigabitethernet "0/0/6"
interface gigabitethernet "0/0/7"
interface gigabitethernet "0/0/8"
interface gigabitethernet "0/0/9"
interface gigabitethernet "0/0/10"
interface gigabitethernet "0/0/11"
interface gigabitethernet "0/0/12"
interface gigabitethernet "0/0/13"
interface gigabitethernet "0/0/14"
interface gigabitethernet "0/0/15"
interface gigabitethernet "0/0/16"
interface gigabitethernet "0/0/17"
interface gigabitethernet "0/0/18"
interface gigabitethernet "0/0/19"
interface gigabitethernet "0/0/20"
interface gigabitethernet "0/0/21"
interface gigabitethernet "0/0/22"
interface gigabitethernet "0/0/23"
interface vlan "1"
ip address 10.116.0.1 255.255.255.0
interface vlan "10"
ip address 10.116.8.1 255.255.248.0
interface vlan "20"
ip address 10.116.16.1 255.255.248.0
interface vlan "6"
ip address 10.115.0.162 255.255.255.252
interface mgmt
interface-group gigabitethernet "default"
apply-to ALL
_______________________________________________________________________
Hopefully there is some useful information in there. Any ideas to help get me started?
