Instant SSID is not coming up for my 225 AP
  • 1.  Instant SSID is not coming up for my 225 AP
    Posted Oct 06, 2014 02:29 AM
    I found a similar question here, but it did not resolve my problem.  I'm powering my 225 via POE+, power light is blinking green (roughly 1s intervals) which means "powering up", enet0 is rapid blinking as it is having activity, but the rest of the lights (namely 5ghz and 2.4ghz) are off. I remember reading in the thread someone else posted of a similar problem that it took him 45 minutes before it came up, I think I've had it for well over that.  Instant SSID is still not showing up.  Aside from a hardware fault, anything else I can look at? I will be trying to console in shortly, but I do not have the proper cable for it.  I set up in DHCP for it to be given an ip, and it is getting it and it pings, but I cannot telnet to it, or maybe I am doing it wrong. Is there another address I need to go to, or a different port I should be using in putty? Or do I just have to be patient (waited a couple of hours)?
    #AP225
  • 2.  RE: Instant SSID is not coming up for my 225 AP
    Posted Oct 06, 2014 02:38 AM
    Try to ssh instead.  Can you get to the gui via https?
  • 3.  RE: Instant SSID is not coming up for my 225 AP
    Posted Oct 06, 2014 11:49 PM
    If it got dhcp and the AP is out of the box(i mean new) then you should be able to see the instant SSID  and you should see 5ghz and 2.4ghz leds blinking
    Can you try consoling it? and show the output? The cisco console cable work just fine....
    Cheers
    Carlos
  • 4.  RE: Instant SSID is not coming up for my 225 AP
    Posted Oct 07, 2014 11:16 AM
    OK I apologize for the delay...I consoled in right now.  This is what I get in conosle:
    APBoot 1.4.0.6 (build 38177)
    Built: 2013-04-25 at 22:52:20
    Model: AP-22x
    CPU0: P1020E, Version: 1.1, (0x80ec0011)
    Core: E500, Version: 5.1, (0x80212051)
    Clock:
    CPU0: 800 MHz
    CPU1: 800 MHz
    CCB: 400 MHz
    DDR: 333.333 MHz (666.667 MT/s data rate) (Asynchronous)
    LBC: 25 MHz
    L1: D-cache 32KB enabled
    I-cache 32KB enabled
    I2C: ready
    DRAM: Configuring DDR for 666.667 MT/s data rate
    DDR: 512 MB (DDR3, 32-bit, CL=5, ECC off)
    POST1: memory passed
    Flash: 32 MB
    L2: 256 KB enabled
    Power: DC
    PCIe1: RC, link up, x1
    dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
    00 00 14e4 43a2 00002 03 80000004 00000000 80200004 00000000
    PCIe2: RC, link up, x1
    00 00 14e4 43a1 00002 03 a0000004 00000000 a0200004 00000000
    Net: eth0, eth1
    Radio: bcm43460#0, bcm43460#1
    Hit <Enter> to stop autoboot: 0
    Checking image @ 0xee000000
    Invalid image format version: 0xffffffff
    Checking image @ 0xeee00000
    Copying image from 0xeee00000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    Aruba Networks
    ArubaOS Version 6.3.0.0 (build 37051 / label #37051)
    Built by p4build@cyprus on 2013-02-04 at 11:16:55 PST (gcc version 4.5.1)
    Memory: 510684k/524288k available (8020k kernel code, 13604k reserved, 532k data
    , 352k bss, 4684k init)
    Processor 1 found.
    Brought up 2 CPUs
    PCI: Probing PCI hardware
    pci 0000:00:00.0: PCI bridge to [bus 01-ff]
    pci 0001:02:00.0: PCI bridge to [bus 03-ff]
    pci 0000:00:00.0: enabling device (0106 -> 0107)
    pci 0001:02:00.0: enabling device (0106 -> 0107)
    ee000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank
    Amd/Fujitsu Extended Query Table at 0x0040
    number of CFI chips: 1
    Enabling watchdog on CPU 1
    Enabling watchdog on CPU 0
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Domain Name: arubanetworks.com
    No panic info available
    Ethernet port 1 mode: active-standby
    ADDRCONF(NETDEV_UP): eth0: link is not ready
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    bonding: bond0: enslaving eth0 as a backup interface with a down link.
    ADDRCONF(NETDEV_UP): eth1: link is not ready
    bonding: bond0: enslaving eth1 as a backup interface with a down link.
    AP xml model 66, num_radios 2 (jiffies 3010)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 16
    radio 1: band 0 ant 0 max_ssid 16
    ethernet_device_event: dev eth0 is up
    ASAP Slowpath initialized
    Starting watchdog process...
    Getting an IP address...
    PHY: eth0 (mdio@ffe24000:00) - Link is Up - 1000/Full
    bonding: bond0: link status definitely up for interface eth0.
    bonding: bond0: making interface eth0 the new active one.
    bonding: bond0: first active interface up!
    ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    192.168.1.149 255.255.255.0 192.168.1.1
    Running ADP...cat: /tmp/master: No such file or directory
    Done. Master is
    killall: nanny: no process killed
    killall: sapd: no process killed
    Sending SIGKILL to all processes.
    Please stand by while rebooting the system.
    Restarting system.
    As far as I can see, it all looks good up until the Running ADP, it is trying to find the master controller, can't then reboots...from my understanding, being the first AP to install in Instant mode, it should allow me to just connect to the SSID to set it up and then subsequent APs will connect to this one as the master. Am I mistaken?
  • 5.  RE: Instant SSID is not coming up for my 225 AP
    Posted Oct 07, 2014 11:21 AM
    Can you try to reset the AP using paperclip?  See the install guide for where that is located, and how to do it.
  • 6.  RE: Instant SSID is not coming up for my 225 AP
    Posted Oct 07, 2014 11:23 AM
    Can you confirm that this is an InstantAP ( IAP-225 )?  Take a look at the back of the AP and look for a small white sticker.  If it states " AP-225 " then it is a Campus AP and requires an external controller.
  • 7.  RE: Instant SSID is not coming up for my 225 AP
    Posted Oct 07, 2014 04:11 PM
    It'sAP-225. I was under the impression that they all came with the Instant setup capability.  I found the following response in anothre thread:
              It is running ADP to look for controller. Did you try to use factory_reset command? If it is not working,           reboot the AP and break the boot  process. Start TFTP and proceed the following command to put                 instant image:
              #upgrade os <tftp_server_ip>:<Instant_image_name>
              For example: #upgrade os 172.16.0.101: ArubaInstant_Orion_6.1.3.1-3.0.0.2_34479
              And reboot the AP after the process, it should be start with the instant image.
    Will something like this work for me? Is the limitation hardware or software related?
  • 8.  RE: Instant SSID is not coming up for my 225 AP
    Posted Oct 07, 2014 04:19 PM
  • 9.  RE: Instant SSID is not coming up for my 225 AP
    Posted Oct 07, 2014 05:03 PM
    So, so sad.  Got a great deal for it. Aruba's page the 225s does not make it clear that IAP and AP are different. It states both methods of management for one page.  I'm guessing from looking at the console info, that the IAPs have more memory to house the entire OS, whereas the AP models don't and require the controller, thus why everywhere I read IAP can be run as AP, but APs cannot be run as IAPs. Sucks. Time to sell it off.
