- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
07-23-2017 06:29 PM
hi,
i have a number of working SSIDs in my Instant cluster. recently, we have tried adding a few new SSIDs & none of them are working. after some digging, i noticed that although disable is unchecked, these SSIDs still show "no" under Active status.
i cant find on these forums or elsewhere a way to change their active status to "yes".
any advice would be much appreciated.
thanks
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Instant SSIDs not active
07-23-2017 07:02 PM
What model IAP?
What regulatory domain?
What version of Instant software?
Colin Joseph
Aruba Customer Engineering
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
07-23-2017 07:05 PM
Sorry for not posting in initial post
i have iap 105s, in USA.
Instant version is 6.4.4.8-4.2.4.6_58505
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
07-23-2017 07:07 PM
The post here: http://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#UG_files/WLAN_SSID_conf/SSIDEnableDisable.htm%3FTocPath%3DUG%2520topics%7CWireless%2520Network%2520Profiles%7C_____6 should tell you how to enable or disable SSIDs.
I don't see a problem with your combination of code, domain or IAP model.
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
07-23-2017 07:22 PM
As i wrote in the original post, the SSIDs are showing up as "enabled" but "active" is still showing as "no".
the above post wont help me. i already tried disabling & reenabling but status still stays as not active.
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
07-23-2017 07:27 PM
here is a screenshot of show network where you can see what i am referring to
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
07-23-2017 07:33 PM
By default SSIDs should not be disabled except maybe for regulatory reasons. Is this a US IAP or a ROW or IL IAP?
Did your IAPs even broadcast the instant SSID?
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
07-23-2017 08:09 PM
I have a number of SSIDs broadcasting properly.
these are US IAPs.
When i first setup the system a few years ago, the instant SSID was broadcast.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
08-02-2017 02:09 PM
Just to put the solution out. i ended up contacting support & after they looked into it further, my model (IAP105) only supports 6 SSIDs. We had to delete a few SSIDs & enable "Extended SSID" to allow 8 SSIDs.
once we got that properly set, my new SSIDs became active.
Hope this will help anyone else that runs into this issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
