Contributor I
Investigate 'roaming' issues in Instant VC
Hi there, a customer of us is reporting roaming issues for e.g. a Samsung Tablet and a Macbook.
They say while walking though the office, the connection dissapears and reconnects later on if they Disable > Enable WiFi on the devices.
This is not good. I want to understand how to investigate roaming issues fromout the Instant VC using Airwave. We don't have remote access via SSH to the instant VC.
Which command should I run fromout Airwave to investigate what a problem can be / and to adjust settings?
ARM Client Match is enabled. CM calcutlating interval is set to 20 seconds and Neighbour matching is set to 60%
Re: Investigate 'roaming' issues in Instant VC
What is the minimum and maximum transmit power under RF> ARM?
Contributor I
I see minimum = 9 and maximum = 18
Okay.  What is the RF utilization on the band that the client is running on?
