Contributor II
Is there a way to force an IAP to check in with Central?
I changed the VLAN and IP address of some IAP's and now they show as down in Central. Is there a way to force a check in? I have rebooted them a couple of times now.
Super Contributor I
Re: Is there a way to force an IAP to check in with Central?
How long have you waited for the IAP to connect to Central? I waited for almost 2 hours in my first setup.
Normal Guy
Contributor II
It's been about an hour and half now. I guess I'll head to lunch. I wonder where the bottle neck is.
The best way to deal with this is to open case with support.  They have access and can probably zero in on your issue.
Contributor II
I did open a case with support. They eventually showed up in Central before anybody contacted me. Took a little over 4 hours.
Super Contributor I
At least it work but I am wondering what is the time neededfor the IAP and Central to link up?
Normal Guy
If the pre-requisites of account creation and device to license assignment are successful, the IAP should not take more than 5 - 7 minutes to show up in the Aruba Central dashboard. The only exception to this is if the device has any configuration related issues.
If you can forward the support case number I will follow up internally.
Super Contributor I
Thanks for the highlight of 5 to 7 mins, will take not e of that.
Normal Guy
Contributor II
Hi Srinip,
Thanks for the offer! I was told that Aruba Activate was having some issues at the time. I have not had a problem since.
Mark
