The IAP should have already got configured for wifi uplink. If not, you'll see that on console. That is expected after a factory_reset. It doesn't get an IP address, so no active ethenet uplink also. As said by Colin, it could be a hardware issue (faulty ethernet port) as well. You need to raise a TAC case.
Rajaguru Vincent
