Occasional Contributor I
MAC address authentication for a WLAN SSID.
Hu guys I'm not able to set MAC address authentication for WLAN SSID. I read the tutorial but i didn't solve my problems. I tried with different profile and i also set up "open  profile".
Could anyone help me?
I don't know if I have to set up some rules on dhcp and dns before setting WLAN
Thanks in advance
Re: MAC address authentication for a WLAN SSID.
What are you trying to do in specific, reynold?
I would like to allow access to wi-fi network by mac address in some PC.
I would like to disable the access by password because too many people know the password.
Building and maintaining a list of mac addresses and maintaining can be time consuming.   The article here:  http://community.arubanetworks.com/t5/Controller-less-WLANs/How-do-I-enable-MAC-authentication-in-Aruba-Instant-using/ta-p/181302 should tell you how to do it.
I'm trying to access de UI (web access) from wired and the page is not displayed.
I did a port scan and only port for telnet and 8080 is opened.
Tried:
https://ip_address
http://ip_address:8080
Any ideia? I need to verify the MAC Authentication table. To check what's the MAC address authorized.
Thank you.
BR,
Pedro
w33w33,
Did you already go through the Instant Initial Setup?  http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/For-the-Beginner-Aruba-Instant-IAP-Basic-setup/ta-p/80744
Thank for your support , the article about instant initial setup that you have posted seems to be what i was looking for..
I also discovered i made some mistakes entering mac address.
