Need evaluation license for Policy Enforcement Firewall for 4 APs on 620 controller. Pls guide
Hello Everyone
I need an evaluation licenses for Policy Enforement Firewall for 4 APs connected to Aruba 620 Controller.
Can you please advise me how to obtain the same?
Re: Need evaluation license for Policy Enforcement Firewall for 4 APs on 620 controller. Pls guide
Do you have an Aruba licensing account? If so, you can generate one
yourself at licensing.arubanetworks.com.
If not, you should contact your Aruba or partner SE.
Tim Cappalli | Aruba Security
Hi
Thanks for your mail. Is there anyway I can get access to the Aruba Licenseing Portal to generate that request ?
Aruba
You can self-register on the site... or work with your local Aruba SE.
JF
