Pass traffic through Virtual Controller IP
Setting up a small Virtual Controller managed network.
Traffic passes through AP IP. Is there a way to pass traffic through Virtual Controller IP?
My goal is to NAT the the VIP through the firewall to a different public IP.
Currenlty, I can only seem to do this through the AP's IP.
Re: Pass traffic through Virtual Controller IP
If you setup an SSID that has a virtual-Controller assigned addressed vlan, it will NAT out of the IP address of the VC.
Colin Joseph
Aruba Customer Engineering
Hi Colin,
Thanks for the reply!
I get this now. When Virtual Controller managed, traffic flows through the Virtual Controller Master IP, not the Virtual IP. This is by design.
I also have the option to create a VLAN and exit through that.
Thanks!
Dear All,
I permit only for the VC IP to access the internet.
there is a way to make the traffic pass through the VC not the Master IP?
Regards
