Print problems in VERY SIMPLE Environment
I have home-network without VLANs. There are some SOHO Switches and some acceesspoints. I'm not sure if this is an instant controller - but I'm sure it's called virtual controller and one of the accesspoints always act as controller.
Now I have problems to access devices via Intra SSID traffic. This should mean that there are two wireless devices connected to the same SSID. I can browse the internet (so they are successully connected) but I'm not able to print on my samsung C480FW (also connected to the wireless network).
This is my simple config:
version 8.3.0.0-8.3.0
syslocation Virtual
virtual-controller-country AT
virtual-controller-key XXX
name blablabla
virtual-controller-ip 192.168.1.250
terminal-access
ntp-server at.pool.ntp.org
clock timezone Vienna 01 00
rf-band all
allow-new-aps
allowed-ap 24:f2:7f:XX:XX:XX
allowed-ap 44:48:c1:XX:XX:XX
arm
 wide-bands 5ghz
 80mhz-support
 min-tx-power 18
 max-tx-power 127
 band-steering-mode prefer-5ghz
 air-time-fairness-mode default-access
 client-aware
 scanning
syslog-level warn ap-debug
syslog-level warn network
syslog-level warn security
syslog-level warn system
syslog-level warn user
syslog-level warn user-debug
syslog-level warn wireless
extended-ssid
hash-mgmt-password
hash-mgmt-user admin password hash XXX
time-range Kids7-21 periodic daily 07:00 to 21:00
wlan access-rule HomeNet
 index 0
 rule any any match any any any permit
wlan access-rule default_wired_port_profile
 index 1
wlan access-rule wired-SetMeUp
 index 2
 rule masterip 0.0.0.0 match tcp 80 80 permit
 rule masterip 0.0.0.0 match tcp 4343 4343 permit
 rule any any match udp 67 68 permit
 rule any any match udp 53 53 permit
wlan access-rule Kids
 index 3
wlan ssid-profile HomeNet
 enable
 index 0
 type employee
 essid HomeNet
 wpa-passphrase xxx
 opmode wpa2-psk-aes
 max-authentication-failures 0
 rf-band all
 captive-portal disable
 dtim-period 1
 broadcast-filter none
 dmo-channel-utilization-threshold 90
 local-probe-req-thresh 0
 max-clients-threshold 64
wlan ssid-profile Kids
 enable
 time-range Kids7-21 enable
 index 1
 type employee
 essid Kids
 wpa-passphrase xxx
 opmode wpa2-psk-aes
 rf-band all
 dtim-period 1
 broadcast-filter arp
auth-survivability cache-time-out 24
wlan external-captive-portal
 server localhost
 port 80
 url "/"
 auth-text "Authenticated"
 auto-whitelist-disable
 https
blacklist-time 3600
auth-failure-blacklist-time 3600
ids
 wireless-containment none
wired-port-profile wired-SetMeUp
 switchport-mode access
 allowed-vlan all
 native-vlan guest
 no shutdown
 access-rule-name wired-SetMeUp
 speed auto
 duplex auto
 no poe
 type guest
 no dot1x
wired-port-profile default_wired_port_profile
 switchport-mode trunk
 allowed-vlan all
 native-vlan 1
 shutdown
 access-rule-name default_wired_port_profile
 speed auto
 duplex full
 no poe
 type employee
 no dot1x
enet0-port-profile default_wired_port_profile
uplink
 preemption
 enforce none
 failover-internet-pkt-lost-cnt 10
 failover-internet-pkt-send-freq 30
 failover-vpn-timeout 180
airgroup
 enable
 multi-swarm
 enable-guest-multicast
airgroupservice airplay
 enable
 description AirPlay
airgroupservice airprint
 enable
 description AirPrint
airgroupservice Sonos
 enable
 id urn:schemas-upnp-org:service:GroupRenderingControl:1
 id urn:schemas-sonos-com:service:Queue:1
 id urn:schemas-upnp-org:service:AVTransport:1
 id urn:schemas-upnp-org:service:RenderingControl:1
 id urn:schemas-tencent-com:service:QPlay:1
 id urn:schemas-upnp-org:service:GroupManagement:1
 id urn:schemas-upnp-org:service:ZoneGroupTopology:1
 id urn:schemas-upnp-org:service:DeviceProperties:1
 id urn:schemas-upnp-org:service:MusicServices:1
 id urn:schemas-upnp-org:service:AlarmClock:1
 id urn:schemas-upnp-org:device:ZonePlayer:1
 id urn:schemas-upnp-org:service:SystemProperties:1
 id urn:schemas-upnp-org:service:ContentDirectory:1
 id urn:schemas-upnp-org:service:ConnectionManager:1
 id urn:smartspeaker-audio:service:SpeakerGroup:1
 id urn:schemas-upnp-org:service:AudioIn:1
 id urn:schemas-upnp-org:device:EmbeddedNetDevice:1
 id urn:schemas-upnp-org:service:EmbeddedNetDeviceControl:1
 id urn:schemas-upnp-org:service:HTControl:1
 id urn:schemas-upnp-org:service:VirtualLineIn:1
airgroupservice itunes
 enable
airgroupservice AmazonTV
 enable
airgroupservice "DLNA Media"
 enable
airgroupservice "DLNA Print"
 enable
airgroupservice DIAL
 enable
airgroupservice allowall
 enable
cluster-security
 allow-low-assurance-devices
The printer has a fixed IP Address 192.168.1.200.
I can ping, samsung software can find the printer but Windows is not able to print on this printer...
When logging in to VC via console when printing:
XXX# show airgroup blocked-service-id
AirGroup Blocked Service IDs
Origin  Service ID  #response-hits
Num Blocked Service-ID:0
XXX# show airgroup blocked-queries
AirGroup dropped Query IDs
Service ID     #query-hits  Thread Num
_homekit._tcp  27           1
_airport._tcp  1            1
Num dropped Query IDs:2
XXX#
What I saw in show airgroup servers verbose is the Rec-dropped on the IP of the printer.
AirGroup Servers
MAC                IP             Type       Host Name          Service     VLAN  Wired/Wireless  Role      Group  Name  AP-Name            Rec-dropped  Rec-filtered  Rec-responded  Last-query        Query Throttled  Resp Throttled  CPPM-Req  CPPM-Rsp  CoA  CPPM Dev-Added  CPPM Dev-Deleted
00:11:32:08:c2:96  192.168.1.220  mDNS,DLNA  DiskStation        DLNA Media  1     wired                                  2OGBuero           2            0             169            Jul 09 20:48:05   0                0               0         0         0
        Sonos
        airprint
        itunes
        sharing
00:0e:58:da:3e:18  192.168.1.16   mDNS,DLNA  sonos000E58DA3E18  DLNA Media  1     wired                                  2OGBuero           0            0             11             Jul 09 20:48:05   0                0               0         0         0
        Sonos
        allowall
00:0e:58:da:15:f2  192.168.1.12   mDNS,DLNA  sonos000E58DA15F2  Sonos       1     wired                                  2OGBuero           0            0             4              Jul 09 20:47:42   0                0               0         0         0
        DLNA Media
        allowall
00:0e:58:c7:59:a2  192.168.1.28   mDNS,DLNA  sonos000E58C759A2  DLNA Media  1     wired                                  2OGBuero           0            0             4              Jul 09 20:48:05   0                0               0         0         0
        Sonos
        allowall
84:25:19:2e:cc:38  192.168.1.200  mDNS,DLNA  SEC8425192ECC38    airprint    1     wireless        Heimnetz               2OGBuero           60           0             22             Jul 09 20:47:47   0                0               0         0         0
        allowall
        DLNA Print
4c:ef:c0:7d:13:8d  192.168.1.61   mDNS,DLNA  192-168-1-61       DIAL        1     wireless                               24:f2:7f:cf:d3:de  0            0             0                                0                0               0         0         0
        AmazonTV
00:0e:58:c7:59:a6  192.168.1.32   DLNA                          DLNA Media  1     wired                                  2OGBuero           0            0             0                                0                0               0         0         0
        Sonos
Num Servers: 19.
So back to my original question:
- How to configure this system that EVERYTHING is passed like a 25€ accesspoint?
- I wan't to allow traffic within the SSID and also from and to wired network (I have SOMETIMES some problems with SONOS Audiosystem too)
Can this have todo with:
 switchport-mode trunk ?????????????
 allowed-vlan all
 native-vlan 1  ???????????????????
 shutdown
 speed auto
 duplex full
 no poe
 type employee
 no dot1x
So what is "No VLAN" and why is standard switchport-mode trunk?
Thank you very much!
regards
Susan
Re: Print problems in VERY SIMPLE Environment
What SSID(s) is/are the Windows laptop and the wireless printer connected to?
For a small single VLAN PSK network, it may be best to disable AirGroup since all devices share the same VLAN and there is no filtering of mDNS services between users.
Charlie Clemmer
Aruba Customer Engineering
both are in the HomeNet SSID.
How can I disable Airgroups to pass all traffic?
regards
Susan
From the webui, under configuration -> Services, ensure that AirGroup services (Bonjour, DLNA, Guest Bonjour multicast, etc) are disabled.
What firmware version is your IAP running? I can provide screen shots for that version of code.
Charlie Clemmer
Nevermind. From the config you posted, you're running 8.3.0.0.
Attached shows the two screens to walk through to get to the settings.
Charlie Clemmer
So disable Airgroup Services will mean that it "bridge" the packets from Wifi to LAN, LAN to Wifi or Wifi to Wifi?
So no "intelligence" there trying to understand what going on, change IP-Addresses or other data in the packets?
I'll try that (not possible at the moment) and I'll come back if it doesn't help...
Thank you!
AirGroup accomplishes two things. It provides a unicast response to mDNS queries so that multicast traffic is reduced. As a side effect of that, it allows for service advertisement for devices that are on different subnets from the clients that want to access those services. Since you're setup has everything on one VLAN, then the cross subnet functionality is not needed. Also, you have broadcast filtering disabled, so the mDNS queries should work without intervention.
Charlie Clemmer
