We recently (end of January) added a AP205 to an Aruba instant cluster which contains 6 AP105s in addition, and are now experiencing problems on the WLAN when the AP205 is plugged in and active.
- The problems start within about 45 minutes to 2 hours after the AP205 becomes active in the cluster, with users complaining about slow/unreliable/intermittent service.
- When IT support then investigates, they discover high latency and packet loss over the WLAN, even to services on the LAN.
- Sometimes, all the SSIDs also dissappear from the air (i.e., they are not discoverable) for a short period (30 seconds to about 2 minutes).
- The only way to resolve these problems are to reboot all the APs, but this is however just a short term solution as the problems start again within about 45 minutes to 2 hours.
- The only permanent solution/work around found so far is to remove the AP205.
Does anyone have any ideas on what the issue could be?
#AP205
