RAP-3WN power supply
  • 1.  RAP-3WN power supply
    Posted Sep 24, 2016 04:33 PM
    Is the power supply that ships with the RAP-3WN a universal power supply (with the bag of snap-on power connector adapters) or is it the same power supply as the 3WNP (requires a localized power cable)?
  • 2.  RE: RAP-3WN power supply
  • 3.  RE: RAP-3WN power supply
    Posted Jul 10, 2017 04:20 PM
    Colin, can you please confirm the EOL status of the RAP-3?  It's still on the May 17 price list and I know someone who wants to buy 3WNPs.
    Thanks!
  • 4.  RE: RAP-3WN power supply
    Posted Jul 10, 2017 07:32 PM
    RAP-3 is NOT end-of-sale.
  • 5.  RE: RAP-3WN power supply
    Posted Jul 10, 2017 10:11 PM
    Thanks!
    It is not.  I made an error.  Sorry.
  • 6.  RE: RAP-3WN power supply
    Posted Jul 11, 2017 10:03 AM
    No problem, I've done worse!   Thanks again.
  • 7.  RE: RAP-3WN power supply
    Posted Sep 26, 2016 03:28 AM
    From the hardware install guide at https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/8442/Default.aspx
    2016-09-26 09_22_53-Aruba RAP-3WN IG Rev 04.pdf - Adobe Acrobat Reader DC.png
    So only the RAP-3WNP requires a separate country specific power cord.
    From my memory, but I don't have a box laying around to check, the 12V power adapter for the RAP-3WN is indeed the block that you put in your power outlet and it comes with some clip-on adapters to fit the local power sockets physically. And the 'standard' AP-AC-UN will fit the RAP-3WN if you need a replacement.
